The studio.ui module allows you to create user interfaces.
Displays a dialog window. The function returns once the dialog has been closed.
See ui.showModelessDialog(description) for further information about the widget description argument.
Displays a dialog window. The function returns once the dialog is shown.
The layout of the dialog is based on a widget description object, which contains the following attributes:
widgetType: A studio.ui.widgetType. A required attribute.widgetId: A string used to reference this widget. Immutable.isVisible: A Boolean which sets widget visiblity.isEnabled: A Boolean which sets whether a widget is interactive.minimumWidth: The minimum width in pixels for a widget (number).minimumHeight: The minimum height in pixels for a widget (number).sizePolicy: A studio.ui.sizePolicy.onConstructed: A Function which is called after the widget is constructed.onTimerEvent(timerId): A callback Function. This will be called periodically after calling startTimer() on a widget. The timerId matches a corresponding timerId returned by startTimer().Applicable to the root widget description in a dialog:
windowTitle: A string for the window title.windowWidth: Width of the window (number).windowHeight: Height of the window (number).onClose: A Function which is called as the widget is destroyed.Applicable to widgetType.Layout:
layout: A studio.ui.layoutType. A required attribute.items: An Array of deck widget descriptions to nest in this layout.contentsMargins: Describes the margins around a layout. An Object with the format { left:[number], top:[number], right:[number], bottom:[number] }.spacing: Spacing between items in pixels (number).Applicable to items within a layoutType.HBoxLayout or layoutType.VBoxLayout:
stretchFactor: Determines how much space an item consumes relative to its siblings (number). Immutable.alignment: A studio.ui.alignment. Immutable.Applicable to items within a layoutType.GridLayout:
row: Row index in grid (number). Immutable.column: Column index in grid (number). Immutable.rowSpan: number of rows for item to span. Immutable.columnSpan: number of columns for item to span. Immutable.alignment: A studio.ui.alignment. Immutable.Applicable to widgetType.Label:
text: A string.wordWrap: A boolean.Applicable to widgetType.PushButton:
text: A string.onClicked: A callback Function.Applicable to widgetType.LineEdit:
text: A string.isReadOnly: A bool.echoMode: A studio.ui.echoMode.onTextEdited: A callback Function.onEditingFinished: A callback Function.Applicable to widgetType.TextEdit:
text: The contents of the text edit, as plain text string. Alternatively, use the html attribute to specify HTML formatted text.html: The contents of the text edit, as a HTML formatted string. This can be used instead of text.isReadOnly: A boolean.Applicable to widgetType.ComboBox:
items: An array of objects with the format { text:[string], userData:[]}. Write-only.currentIndex: A number.currentText: A string. Read-only.currentUserData: Read-only.onCurrentIndexChanged: A callback Function.Applicable to widgetType.CheckBox:
text: A string.isChecked: A boolean.onToggled: A callback Function.Applicable to widgetType.Slider:
orientation: A studio.ui.orientation.value: A number.range: An object with the format { minimum:[int], maximum:[int] }.onValueChanged: A callback Function.Applicable to widgetType.SpinBox:
value: A number.range: An object with the format { minimum:[int], maximum:[int] }.onValueChanged: A callback Function.Applicable to widgetType.PathLineEdit:
text: A string.label: A string. Immutable.caption: A string. Immutable.pathType: A studio.ui.pathType. Immutable.onEditingFinished: A callback Function.Note that all attributes are optional except for those marked as required.
Widget callbacks functions are called with the this value set to the corresponding widget. You can dynamically get and set the various attributes available in the widget description using the corresponding 'getter' and 'setter' (e.g. calling widget.setVisible() will modify the widget.isVisible() attribute). Attributes marked as immutable do not have a 'setter' function. For example:
widgetType: ui.widgetType.PushButton,
text: "Show Alert",
onClicked: function() {
// displays an alert with the text of the button that was clicked
alert("The button's text is: "; + this.text());
From the context of a callback, a number of additional member functions are available for widgets:
findWidget(widgetId): Returns a sibling widget with the matching widgetId.closeDialog(): Closes the parent window.startTimer(intervalInMs): Starts a timer with the intervalInMs and returns a timerId. Once a timer is started, the onTimerEvent() function of the widget description will be called periodically. The timerId can be used to differentiate between timers when multiple timers have been started.stopTimer(timerId): Stops a timer with the given timerId.For an in-depth example of writing your own widgets, see the EngineDesigner.js example in the Scripts folder of the FMOD Studio install directory.
An enumeration corresponding to different widget types available within a UI widget description. Possible values are:
Spacer: A blank widget.Layout: A container widget. Must specify a corresponding layout type.Label: A text label.PushButton: A clickable button.LineEdit: A single-line text entry widget.TextEdit: A multi-line text entry widget. Supports plain text and HTML. ComboBox: A drop down. CheckBox: A boolean check box with a text label. Slider: A slider that with an integer range. SpinBox: A number box with an integer range. PathLineEdit: A convenience widget providing a single-line text entry widget and a "Browse" push button to allow user to input a file or a directory path.An enumeration corresponding to different layout types available within a UI widget description of widgetType.Layout. Possible values are:
HBoxLayout: A horizontal layout. Items are spaced evenly, unless a stretchFactor is specified. VBoxLayout: A vertical layout. Items are spaced evenly, unless a stretchFactor is specified. GridLayout: A grid layout. Items can specify a row, column, rowSpan and columnSpan.An enumeration corresponding to the alignment of an item within a layout widget. Possible values are:
AlignLeft AlignRight AlignHCenter AlignJustify AlignAbsolute AlignTop AlignBottom AlignVCenter AlignBaseline AlignCenterAn enumeration corresponding to the size policy of a widget. This determines how much space it will try to consume within its layout, and how it will react when more or less space is made available.
Separate vertical and horizontal size policies will need to be specified. For example: sizePolicy: { horizontalPolicy: studio.ui.sizePolicy.Fixed, verticalPolicy: studio.ui.sizePolicy.Fixed }.
Please note that the size policy only applies to the individual widgets and not to the size of the dialog window.
Fixed - the widget can never grow or shrinkMinimum - the widget can expand but not get smaller than the minimumWidth/minimumHeight specified in the widget description objectMaximum - the widget can get smaller but can not expand beyond the maximumWidth/maximumHeight specified in the widget description objectPreferred - the widget can be expanded or shrunk, but there is no advantage to it being larger than the minimumWidth/minimumHeight specified in the widget description objectMinimumExpanding - the widget can make use of extra space, so it should get as much space as possible, with a preferred minimumWidth/minimumHeight specified in the widget description objectExpanding - the widget can make use of extra space, so it should get as much space as possible Ignored - the widget will get as much space as possibleAn enumeration representing an orientation. Possible values are:
Horizontal VerticalAn enumeration corresponding to the echo mode of a LineEdit widget. This can be used to display asterisks instead of characters when entering a password. Possible values are:
NormalNoEchoPasswordPasswordEchoOnEditAn enumeration corresponding to the different path types the PathLineEdit supports. This controls the behavior of browser dialog presented. Possible values are:
OpenFile: User will be able to select an existing file. SaveFile: User will be able to specify a new file name at a given directory.Directory: User will be able to select an existing directory.
