model.Parameter specified.The base class for tracks that can contain instruments.
See Also: model.Sound
A track within an event that is associated with a mixer group.
See Also: model.Event, model.MixerGroup
A logic track containing logic markers.
Creates an automation track for a given property of an automatable object.
AudioTrack.addAutomationTrack(
automatableObject,
propertyName
Returns the automation track ManagedObject.
Automation can be present even if the automation track is hidden.
// adds an automation track for a master track's volume
var event = studio.project.workspace.addEvent("New Event", true);
var masterTrack = event.masterTrack;
var automationTrack = masterTrack.addAutomationTrack(masterTrack.mixerGroup, "volume");
// adds an automation track for a gain effect's gain
var gainEffect = masterTrack.mixerGroup.effectChain.addEffect("GainEffect");
var automationTrack2 = masterTrack.addAutomationTrack(gainEffect, "gain");
See Also: Tracks
Adds an instrument to the track on the model.Parameter specified.
GroupTrack.addSound(
parameter,
soundType,
start,
length
Returns the model.Sound ManagedObject.
See Also: Tracks
Retrieves the mixer bus at the relative path specified.
GroupBus.getItem(
path
Returns the model.MixerBus at the relative path specified. Returns undefined if the bus cannot be found.
var bus = studio.project.workspace.mixer.masterBus.getItem("sfx/player");
Adds a destination marker to the marker track at the given position.
MarkerTrack.addNamedMarker(
name,
position
string value to assign the marker when created.Returns the named marker ManagedObject.
Adds a destination region to the marker track at the given position with the given length.
MarkerTrack.addRegion(
position,
length,
name,
loopMode
string value to assign the new region.project.regionLoopMode.Looping if loopMode is undefined. The loop mode can be set by passing in a valid loopMode argument, as described by the Project.regionLoopMode enum.Returns the newly created region's ManagedObject.
Adds a sustain point to the track at the given position.
MarkerTrack.addSustainPoint(
position
Returns the SustainPoint ManagedObject.
Adds a transition marker to the track at the given position.
MarkerTrack.addTransitionMarker(
position,
destination
NamedMarker or LoopRegion.Returns the newly created TransitionMarker ManagedObject.
Adds a transition region to the track at the given position with the given length.
MarkerTrack.addTransitionRegion(
position,
length,
destination
NamedMarker or a LoopRegion.Returns the TransitionRegion ManagedObject.
