model.Modulator applied to a single property of a model.AutomatableObject.model.Modulator that affects the pitch of an instrument across the range of model.GameParameters.model.Modulator that applies a function to a single property of a model.AutomatableObject.model.AutomatableObject's property.model.Modulator that applies random values to a single property of a model.AutomatableObject.model.Modulator that uses the input signal from an external model.Sidechain to apply random values to a single property of a model.AutomatableObject.An AHDSR curve model.Modulator applied to a single property of a model.AutomatableObject.
See Also: AHDSR Modulator
A model.Modulator that affects the pitch of an instrument across the range of model.GameParameters.
See Also: Autopitch Modulator
A low frequency oscillator model.Modulator that applies a function to a single property of a model.AutomatableObject.
See Also: LFO Modulator
The base class for objects which additively affect the value of a model.AutomatableObject's property.
See Also: Modulator
A model.Modulator that applies random values to a single property of a model.AutomatableObject.
See Also: Random Modulator
A model.Modulator that uses the input signal from an external model.Sidechain to apply random values to a single property of a model.AutomatableObject.
See Also: Sidechain Modulator, Sidechain Effect
