The studio.menu module provides access to menu bar items.
Registers a menu item under the "Scripts" menu, based on the description object:
name: [string] (required),
execute: [function] (required),
keySequence: [string],
isEnabled: [bool] (dynamic),
isChecked: [bool] (dynamic),
subMenuItems: [array(description)] (dynamic),
The name property must be a string, but other properties can specify a function to be called dynamically, which returns a value of the expected type (for example, you may want to reevaluate isEnabled based on what's selected). Using a '\' character in the item name will place it in a submenu. Adding an item with a name containing all dashes ('-' character) will result in a separator being added.
name: The name of the menu item that appears in the menu.execute: The function to be called by the menu item.keySequence: The keyboard shortcut for the menu item.isEnabled: Determines when the menu item becomes enabled.isChecked: Determines whether a checkmark appears next to the menu item.subMenuItems: Specifies the items that appear in the menu item's associated submenu, if any.Returns true if the operation succeeds, or false otherwise.
Removes a menu item that was added with menu.addMenuItem(). The description argument must match a description that the menu item was added with.
Returns an Array of menu item descriptions added with menu.addMenuItem(). The order of the Array matches the order in which the items were added.
