Unity Integration 2.03
// This is a Unity behaviour script that demonstrates how to use
// Programmer Sounds and the Audio Table in your game code.
// Programmer sounds allows the game code to receive a callback at a
// sound-designer specified time and return a sound object to the be
// played within the event.
// The audio table is a group of audio files compressed in a Bank that
// are not associated with any event and can be accessed by a string key.
// Together these two features allow for an efficient implementation of
// dialogue systems where the sound designer can build a single template
// event and different dialogue sounds can be played through it at runtime.
// This script will play one of three pieces of dialog through an event
// on a key press from the player.
// This document assumes familiarity with Unity scripting. See
// https://unity3d.com/learn/tutorials/topics/scripting for resources
// on learning Unity scripting.
// For information on using FMOD example code in your own programs, visit
// https://www.fmod.com/legal
using System;
using System.Collections.Generic;
using UnityEngine;
using System.Runtime.InteropServices;
class ScriptUsageProgrammerSounds : MonoBehaviour
FMOD.Studio.EVENT_CALLBACK dialogueCallback;
public FMODUnity.EventReference EventName;
#if UNITY_EDITOR
void Reset()
EventName = FMODUnity.EventReference.Find("event:/Character/Radio/Command");
#endif
void Start()
// Explicitly create the delegate object and assign it to a member so it doesn't get freed
// by the garbage collected while it's being used
dialogueCallback = new FMOD.Studio.EVENT_CALLBACK(DialogueEventCallback);
void PlayDialogue(string key)
var dialogueInstance = FMODUnity.RuntimeManager.CreateInstance(EventName);
// Pin the key string in memory and pass a pointer through the user data
GCHandle stringHandle = GCHandle.Alloc(key);
dialogueInstance.setUserData(GCHandle.ToIntPtr(stringHandle));
dialogueInstance.setCallback(dialogueCallback);
dialogueInstance.start();
dialogueInstance.release();
[AOT.MonoPInvokeCallback(typeof(FMOD.Studio.EVENT_CALLBACK))]
static FMOD.RESULT DialogueEventCallback(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr)
FMOD.Studio.EventInstance instance = new FMOD.Studio.EventInstance(instancePtr);
// Retrieve the user data
IntPtr stringPtr;
instance.getUserData(out stringPtr);
// Get the string object
GCHandle stringHandle = GCHandle.FromIntPtr(stringPtr);
String key = stringHandle.Target as String;
switch (type)
case FMOD.Studio.EVENT_CALLBACK_TYPE.CREATE_PROGRAMMER_SOUND:
FMOD.MODE soundMode = FMOD.MODE.LOOP_NORMAL | FMOD.MODE.CREATECOMPRESSEDSAMPLE | FMOD.MODE.NONBLOCKING;
var parameter = (FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES)Marshal.PtrToStructure(parameterPtr, typeof(FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES));
if (key.Contains("."))
FMOD.Sound dialogueSound;
var soundResult = FMODUnity.RuntimeManager.CoreSystem.createSound(Application.streamingAssetsPath + "/" + key, soundMode, out dialogueSound);
if (soundResult == FMOD.RESULT.OK)
parameter.sound = dialogueSound.handle;
parameter.subsoundIndex = -1;
Marshal.StructureToPtr(parameter, parameterPtr, false);
else
FMOD.Studio.SOUND_INFO dialogueSoundInfo;
var keyResult = FMODUnity.RuntimeManager.StudioSystem.getSoundInfo(key, out dialogueSoundInfo);
if (keyResult != FMOD.RESULT.OK)
break;
var soundResult = FMODUnity.RuntimeManager.CoreSystem.createSound(dialogueSoundInfo.name_or_data, soundMode | dialogueSoundInfo.mode, ref dialogueSoundInfo.exinfo, out dialogueSound);
parameter.subsoundIndex = dialogueSoundInfo.subsoundindex;
break;
case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROY_PROGRAMMER_SOUND:
var sound = new FMOD.Sound(parameter.sound);
sound.release();
break;
case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROYED:
// Now the event has been destroyed, unpin the string memory so it can be garbage collected
stringHandle.Free();
break;
return FMOD.RESULT.OK;
void Update()
if (Input.GetKeyDown(KeyCode.Alpha1))
PlayDialogue("640148main_APU Shutdown");
if (Input.GetKeyDown(KeyCode.Alpha2))
PlayDialogue("640165main_Lookin At It");
if (Input.GetKeyDown(KeyCode.Alpha3))
PlayDialogue("640169main_Press to ATO");
